- Joined
- 28 Dec 2016
- Messages
- 115
- Reaction score
- 4
- Country
Am redoing the kitchen which has involved altering positions of sockets switches etc. My question is the depth of metal back boxes. For example I had to move the cooker switch only some 60mm to the left. So I chopped out the blockwork, soft grey block, which is fine but as before the back box is now set some 5mm below this blockwork surface. I must point out the wall is blockwork covered with render of about 10mm depth. Taking out the old backbox disturbed some of this render so I pulled any loose render away to be left with firm material. Now after all this rambling my question is do I pack out the rear of the backbox,to bring it level with the blockwork, if so with what or just fi it up against the blockwork. Also how do I fill in the spaces surrounding the backbox so when I get a plasterer around he can crack on with a new skim coat. If it is suggested I fill in the area around the blockwork what should I use. I happen to have a bag of one coat render. And finally will render adhere to previously used polyfilla?
