Back Panel in Sink Unit
2 May 2007
Hi
I am about to install the plumbing for my sink but the unit has a back panel, are these generally removed at installation or is there some fancy cutting needed?
I think its 800 wide so I am guessing I could take out a middle section.
Just not sure if I should just remove the whole thing
Lee
Good morning Lee, it depends on how big a gap you need, a photo might be a wise move here so we can advise better, usually they’re just cut with hole saws or spade bits.
The feeds are behind the panel so I need to access them
Yeah unit already in, worktop in and sink in. Just need to fit the tap and the waste but the back
panel is in the way
Again, I think a photo would be best, I found not sounds like the whole panel will need to come out.
I'll sort one, looks like the tap will be on the inside of the panel so in theory I just need to be able to bring the feeds through the back to the taps and then the waste
