Ball valve 300mm arm
4 Mar 2013
Bradford
I have a ball valve with a 300mm arm. 1/2 ones are have a 200mm arm. Not sure whether this one is a 3/4 or inch ball valve.
I have attached a picture
Thanks it would be a bigger washer on this sized valve?
Probably, take it out and if not too bad a condition you can turn it round the other way and refit it. Not a long term solution but would let you source a new one.
Thanks the nut wants cracking abit to turn it square. It's at a bit of an angle so isn't helping matters
