Ball valve nut ?
26 Jun 2004
London
Does anyone know of a box spanner to fit these?
Tony
Thanks for that Buck. Although some can be quite pricey, if I can correctly identify the size then one of them or the sponsored ad listings is likely to suit the bill !
Ok i will ask WHY do you need a box spanner for these ??
Its on one of those old insulated combined cylinders where the metal cladding is about 35mm out from the nut preventing normal access with an open spanner.
To make matters worse like most its fitted with only about 90 mm space to the ceiling!
Tony
