ballast fixture failed install
24 Jul 2011
Glasgow
<Please shout me down if image sizes are too big etc>
Old ballast started to flicker just as the washer went on peak spin cycle
tried second bulb ( tube?) and 3 starters
same results
flickering all the way along and nearly starting
local store offered a new 58watt ballast starter and blub for £15.90
said it was dead easy install
I have seen 'rose' fixtures hanging from previously fluroscent light positions , so I had a crack at it
failed
can you advise - all input philosophically received
THX
It is unclear where the blue wires are going so the pictures are worthless.
As for the cable joints, they need to be done properly they are dangerous.
I would suggest you contact someone competent and the bloke in the
shop should not be giving you advice like that.
