Bargain?!
T
toasty
Chaps,
I just bought from eBay the following:
C7-A20 (240VAC RELAYS) X 41
C60HD-D2 (240V BREAKERS-2A) X 26
C60HD-D4 (240V BREAKERS-4A) X 6
C60HD-D6 (240V BREAKERS-6A) X 12
C60HD-D10 (240V BREAKERS-10A) X 2
Now I know the breakers (Merlin Gerin BTW) are odd current ratings and trip characteristics (They are all D curve)
But for 1quid (yes a pound!!!) I think it's a bargain.
They turned up yesterday, in good condition. Even if I only end up using one of the items above you have to admit it's a good price.
-Dan
Ahh, I see someone still has some of those fake Chinese imports kicking around, turns out they are just a real-ish looking enclosure with nothing more than a switch inside.
I doubt they're D curve, probably more like 'Z-curve' lol
Be very carefull of these, or any cheap MCB's or RCD's, I would only ever buy from a reputable wholesaler.
Got a reel of 2.5mm² and a car battery?
Run some tests.
If they appear not to work, cut one open and see what's inside.
If they are fakes do not just ask the seller for a refund - get onto TSO, he needs prosecuting, and get onto M-G - they might want to take action for trademark infringement.
Are they new or second hand though.
How much for postage.
Sounds like someone has stripped out an old H+V panel
I'm sure they are genuine, they are used and from a reputable ebayer. I just think it was a case of a bad advert not getting much attention (the ad appeared to suggest you were only bidding on one item, when in fact it was all 80-odd!!!)
I will test them though, as I say will probably not use many, but I think at this price they are a steal!!
Second hand, postage was a fiver I think.
With a name like hydrotechnic (the seller) I suspect it was some kind of pump control panel yes.
Seems odd for a panel having so many 240 v relays though, usually they would be 24volt
I think the relays are 10amp DPDT.
No din rail on their own, but are the ones that can plug into DIN rail bases
