Hi. I currently have 22mm Hot and cold pipes running from a hot water cylinder and gravity fed cold water tank feeding my current bath mixer tap. The new bath mixer I’ve ordered has 1/2 inch connectors rather than 22mm. Is reducing to 15mm at the end of the run before hooking up to the mixer tap going to significantly reduce the speed the bath fills at? Note the shower runs from a different source so not impacted.
