Bath taps and shower question.
27 Aug 2013
Worcestershire
Hi all
last summer I ripped out our heating system and replaced with a combi boiler, went for a big (ish) one to get a nice high flow rate for a good shower. Currently have a 9.5KW electric shower, but I have never found them to be that great compared to running off a combi. The bathroom was fitted only 2 years ago so I don't want to do any smashing, bashing or cutting if I can avoid it. My problem is that my plan of just getting a bath / shower mixer tap and shower riser has been scuppered by the completely non-standard taps the last owner of the house had installed. The actual 'tap' parts are separate from the spouty bit, so there are 3 holes in the bath, but not spaced so I can cover them with a standard mixer tap. the spouty bit is a rectangular affair that rises from the bath abou a foot and the turns into a sort of channel so that it is like a waterfall type effect, it also has some rather pointless LEDs in it to illuminate the water :?
any ideas how I can fit a shower to this little setup without leaving holes in the bath, smashing tiles off the walls or causing any other kind of destruction?
Many thanks.
What are the hole centres, are they at the standard distance (180mm IIRC)?
Thoughts:
Are the outer of the 3 holes spaced so that a mixer of some sort would fit. Then find/bodge a chrome blanking plate for the middle hole.
Eg (first google hit) http://www.ebay.co.uk/itm/Tap-Hole-Blanking-Plug-Stopper-Kitchen-Sink-Bathroom-chrome-/230779161224
Use a traditional style mixer with cranked legs that are adjustable for different sized holes?
Use a monoblock single hole bath/shower mixer and blanks in the other two holes?
