Hello
Looking at other houses in my area, it seems that there should be a hopper below my bath, sink and shower waste pipe, where it exits the outside wall. The previous owner had instead connected this 40mm pipe to a standard down pipe, using silicon seal to fill the mismatch in pipe size. The down pipe goes straight to a gully. The plugholes always smell of drains in the bathroom.
So last week I bought a hopper and installed it below the waste pipe, on the top of the down pipe. The drains smell has now gone away. However, when I empty the bath, the hopper overflows badly. I've checked and it's not blocked.
Is the position where the waste pipe enters into the hopper critical? I could adjust that so it is exactly above the down pipe opening. Or is there anything else I can do?
I got the hopper from Wickes and it is approx 25cm by 8cm. I've seen ones the same size fitted on other houses in the area.
Ta for any advice
Ta for any advice
