Bathroom extractor fan isolation switch wiring
8 May 2012
Cheshire
A simple question in case I make a horlicks of it. Bathroom extractor (timer) fitted with 3 core and earth. It'll go straight to the attached isolation switch. How is it wired from there please?
It's up to you how you use L1 & L2 for permanent and switched live - either way round is fine.
It depends on how the fan is wired.
At the fan -
You have
Permanent Live
Switched Live and
Neutral.
PL probably brown.
The other two - depends
At the switch -
You have
L1 in L1 out
L2 in L2 out and
N in N out
Obviously you put the neutral in N
The other two don't really matter as long as ins and outs match.
I would put PL in L1 and SL in L2
Wires don't know what colour they are, it's the copper bit inside that complains if you mix them up.
Hi EFL,
with the switch in question though would the load (fan) go to the respective COM terminals?
There are no COMs on a fan isolator.
It looks like the body is also used for two-way switches so ignore the COMs.
Just three ins and outs (although in and out don't matter).
I have found another online like it and it is the right switch.
Just go by the L1, L2 and N markings - top and bottom.
