Bathroom Help!!!!!!
7 Mar 2007
London
I need to tile behind my shower/bath. Currently the bottom two rows of tiles are loose/falling off as the plaster behind is wet and hence tile adhesive won\\\'t stick.
My girlfriends dad has said take off all the tiles, let the old plaster dry then use bonding on top to fill any gaps then tile directly onto this but I am wary. Should I use some marine ply or this aquapanel stuff i have heard about? The only problem with aquapanel is that you have to build a frame to attach it to, requiring me to move my bath out from the wall about 5cm which I am not sure I can do due to the pipes.
Does anyone have any suggestions/tips, could I not attach either marine ply or aquapanel directly onto the wall as long as I ensure it is all straight then tile onto this?
All comments appreciated.
do it right.
cut out wall panel to stus apply backer board (cement board) sheets come 30 x 60" screw to studs now tile as usual use epoxy glue for tile work moisture proof and seal grout
Not sure what is behind, will check tonight. If it is plaster borad i guess it should just be removed and i can use the existing studs.
What if it is plaster on breeze block?
