Bathroom LED's
11 Dec 2012
My brother says he has too many LED's in his bathroom. 6 in total in the ceiling.
It is very bright when you put the light on.
Any ideas as to what he can do as he hates it being so bright in there?
Not sure what LED's are currently in situ. Would changing them help? Or, can he remove a few? Is that permissable?
Lights are controlled by a pull cord (flat roof).
Any advice welcome.... Thanks
Trying lower wattage bulbs would be the obvious thing to try. And of course some fittings could be removed.
For nighttime use I have some wall lamps to the sides of the mirror with pull cords
And a ceiling globe for full light, separately switched by the door.
My previous house had double switches by the door,
Not difficult if you have access above the ceiling.
Downlighters can be dazzling if you are lying in a bath.
I have 5 GU10 lamps for my stairs/landing, I have the centre on switched at wall, the outer 4 can only be switched on/off with zigbee relay, not ideal, but works very well, and centre bulb is a smart one colour changing so can dim right down or/and change colour.
Today there are so many easy options, swapping to smart bulbs seems the easiest, but only an option for GU10 type, the G5.3 type typically 12 volt, both loosely called MR16 lamps is not so easy, much depends on the power supply.
The problem with the 12 volt lamps is many of the power supplies used have a minimum output, typically 30 - 50 watt, so 6 x 5 watt would work, but remove a bulb and it may switch off, or flash.
There are now so called electronic transformers which will work from zero, but as it stands we have no idea if 230 volt or 12 volt.
