Bathroom mirror demisting with underfloor heating or pads?
30 Dec 2013
We're putting a large mirror in the bathroom c1.8m x 1.2m. I was considering using some underfloor heating matting to use for demisting.
Has anyone used this before? Will it work? Or do we have to go down the route of demisting pads (I think I would need at least 2 as don't just want a small square) so was wondering if underfloor matting would be a cheaper option if feasible.
Any suggestions welcome. Thanks
Our local wholesale retailer (QVS) has a 1.5m2 mat, which says can be cut around obstacles. So the plan was to cut the mat (without cutting the cable) and double it back on itself so effectively ending up as 1.5 x 1.0 m allow space to put adhesive on the edge of the mirror for fixing to the wall.
http://www.qvsdirect.com/comfort-zone-1-5m2-150w-underfloor-heating-mat
The main part of it is in zone 3, but it does edge into zone 2 (about 20cms at the bottom above the sink) and 20cms on left edge near shower. The fan isolator switch to be used for connection is in zone 3.
Would this be ok do you think?
My main concern would be the UFH mat getting too hot and breaking the mirror. With an UFH mat you'll also need a seep rate temperature probe and thermostat. Demisting pads self regulate their temperature, and are also much thinner than an UFH mat.
For what you'll save, I really don't think it'll be worth all the extra hassle.
