Strange problem - not sure if has just started or if I have just noticed it. The bathrooms are really hot in this warm weather and the central heating thermostat is still set low to stop central heating from coming on. This happens even when the hot water is off on the main controller. The bathroom rads are hot and I can hear a pump running. If I turn the central heating off on the main controller the pump stops running after about 30 seconds. I'm worried that a lot of heat is going to waste and electricity wasted running a pump when it is not needed.
The reason the central heating is on - well for some reason the hot water doesn't work unless both the central heating and hot water are on the main controller.
Any tips on what to do to fix this appreciated!
Cheers
Cheers
