I am trying to replace a bathroom light switch with a brushed steel one. The switch is outside the bathroom by the door. When I had a look it is actually a double pole isolator not an ordinary light switch. I can't see the reason for this. There are only two lights on the switch and the switch is definitely part of the lighting circuit. Can I change the switch for an ordinary light switch and if I do is it acceptable to connect the neutral side of the circuit with a connector block. There is plenty of room in the back box
The installation was professionally done in about 1990, it has the old double D fittings on it.
Ps I know the steel switch plate needs earthing, which is not a problem.
