- Joined
- 27 Jan 2008
- Messages
- 27,694
- Reaction score
- 3,356
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My laptop a Sony has had battery problems since the day I got it, it would only last a few minutes, but used on mains, so did not really matter, until I realised the power supply was running rather hot, so I bought a new battery.
However before really using the new battery the hard drives failed, and it took a few months to get it fixed. When I got it back it had Windows 7 instead of Vista and battery showed zero charge, it did not seem to charge, but then it gradually went to around 79% after which point it has been gradually going down again, it says plugged in charging when you hover over the icon but it has slowly over last few weeks being going down and down and last time I looked it was 9% the battery icon has also been showing a lower and lower bar reading.
There are a number of things which could be wrong, from a faulty battery, or Windows 7 not having correct drivers for the PC. Now I don't mind buying another battery, but only if the battery is faulty.
Now I unplugged the power supply at 9% and as one may expect it warned me to shut it down or get a mains supply, one plugging the power supply back in the icon seems to be showing an animated battery level showing it moving from near empty to full and back again to near empty, don't remember it doing this before, not sure if due to trying to find and install drivers from the Sony US web site, or if something has changed.
However on returning animated level icon seemed to have stopped and stuck at 10% charged, it has gone up from 9% but not much, and I wonder if I did see the animation or if it was just due to plugging in power and so the post.
Should the charge icon be animated, and any ideas on how to find if fault is battery or Windows 7.
