- Joined
- 10 Apr 2016
- Messages
- 6
- Reaction score
- 0
- Country
I was wondering if anybody could help! We have not hot water or heating.
The Fan/Flue fault LED is flashing.
We have had a new fan installed as the old one sounded like the bearings had gone. This didn't fix the issue.
I removed the flue (vertical through garage roof) and there were no splits or damage. Looked absolutely fine.
I've also tried another PCB board from a known working 105e. Still not working. It's also had a new pressure switch fitted.
In the beginning, if there was a call for water, if you lifted the cover from the boiler to allow more air in, it would fire. This no longer helps.
When asked for hot water or heating, you can hear the relays clicking on the PCB and then the fan kicks in. Then that's it, a few seconds later the FF fault LED blinks.
Can anybody help?
Thanks,
Nick
Can anybody help?
Thanks,
Nick
