baxi 105e fault
23 Feb 2012
Cumbria
baxi 105e boiler central heating runs all the time when on timed. if when the room thermostat cuts in boiler goes into fault safety thermostat cuts in but pump still runs any help
Where did you see it described as a safety thermostat LED ?
Does the fan run at full speed?
What happens when you reset the boiler?
Overheat thermostat has operated or is faulty.
Is there Continuity across thermostat terminals?
