On Saturday night my boiler suddenly stopped working, a quick investigation showed that one of the copper tracks on the pcb had burnt out. No problem I thought get a new pcb and job done. Replaced with new board (part no. 5112380) with the result that the DHW works fine but the CH goes through the ignition sequence, fires up for about a second and then shuts down. It will go through this sequence three times before showing a flame failure (30 light flashing). Resetting the boiler will clear the light but the same thing will happen each time. I've tried keeping it in the reset position for up to 15 seconds but still no joy. Have had the flame sensor replaced because the IM points to this as a possible cause, but still the same. In frustration I have soldered a piece of wire on the old board bridging the burnt out track put that back and the boiler is working fine in all respects, but each time I try the new board the CH will not fire up. Although its all working with old board in place I would like to put the new one in because I'm thinking there is possibly something wrong with the old one for it to burn a track out like that, so any help would really be appreciated here. Thanks in advance.
