Hi everyone
Can you please help with this if you can I got baxi 105e boiler. Up until last night the boiler was working. This morning it was not firing up. When I reset it the pump start running but after 15 second the pump fault light lit up but the pump is still ruing for as long as the boiler is on but the boiler is not firing. No ignition or fan are working. Could you let me know is the pump that at fault or if the PCB board I mean the pump is running its not jammed.
Thank for your help
Read more: http://www.diynot.com/diy/threads/baxi-105e-pump-fault.420361/#3263894#ixzz3LEEpsYzA
Thank for your help
