Baxi 105e
16 Feb 2022
Baxi 105e is showing the dreaded cutting out issue.
When running either hot water or central heating, the boiler heats the water, the burner then stops prematurely and the water runs cold for about 10 seconds, then the burner comes back on and the water warms again. Rinse and repeat every 20-30 seconds. Having a shower is difficult!
Adjusting the temperature dial for either makes no difference.
I suspect the system is a bit dirty, and have added some cleaner, but I can't get it to a high temperature to really work.
Is this likely to be a faulty thermostat, or an issue elsewhere?
If it does it on heating as well, then could be pump, blocked heat exchanger, et al.
