BAXI 105HE - Hot water only works when boiler is reset?
26 Dec 2009
Somerset
I've been reading the various posts concerning the poor design of this boiler and my plumber has fitted an external expansion vessel (£150+vat seemed a bit steep though) but his has cured the pressure drop.
The hot water however stops after a while. Turning the power off and back on does the trick but only for 10 mins or so.
Is this a straightforward but unconnected fault?
About right £.
It sounds like the internal store is heating up but the boiler isn't noticing when you open a tap. Similar department to the EV but probably a small rubber diaphragm split, a switch faulty, or a pin seized.
