Hi, Boiler is dead no lights on front, nothing, changed fuse in socket on wall ( 3 amp). Still Zilch. Help please! is there a fuse in boiler? Much obliged for help.
theres a fast blowing fuse on the pcb.but replacing this might not be the prob usually pump jamming etc can cause it blow.or the pcb might have gone down. if using a multimeter test power to the board.preferbly id get someone in if you dont know what your doing.
Ok, located fuse, tested with multimeter, fuse ok, tested other bits as per instructions, these point to new p.c.b. Gutted. one consolation, covered by BG 50 quid callout scheme, so new pc.b for 50 quid. Happy.
