I would be grateful for any advice on this before I contact a local heating engineer.
I have a Baxi Bermuda 51/5 back boiler, room thermostat and Honeywell ST6400C programmer and I believe it is a fully pumped sytem.
The problem is that with everything in the off position the pump is always working and hot water in the surrounding pipes, CH does not come on so assume diverter valve is OK? Only when I turn off fused supply to system does the pump stop.
Kind regards
Kind regards
