Hello
Hoping someone can help/point out where I'm going wrong.
I've been reading this thread and have fitted a CM927 to my baxi 105HE following the instructions, & advice found on this site. I've done everything exactly as per the manual but it doesn'y seem to work! I've removed the link between terminal 1 & 2 and done all the wiring correctly. The CM927 remote thermostat communicates with the reciever & I can hear the relay clicking in the receiver when I turn from 'off' to 'manual' but it doesn't stop & start the boiler.
I've got the switch on the boilers mechanical timer set to the 'I'/constant position but this just makes the boiler on constantly as before. I'm pretty sure I've tried every combination of settings on the boiler panel but nothing seems to make the boiler respond to the CM927, everything seems to be wired & meters out right - I'm thinking that maybe there's something wired wrongly in the boiler or that something else is wrong with it - the CM927 seems to be functioning perfectly well.
All very confusing & frustrating!!
Any help and advice would be greatly appreciated.
Stephen
Stephen
