I have a baxi duo-tec he24 which is causing some puzzlement at the moment.
Central heating is working fine.
But direct hot water is not working.
When I turn the tap on - the Hall effect sensor works (red LED). The indicator on the front panel indicating that it recognises water is being drawn lights up.
But the boiler doesn't fire (though of course it does when only CH is needed).
The DHW NTC temperature sensor appears to be fine (resistance about right, and the measured temperature shown on the LCD display is what I would expect).
No error codes are shown.
The diverter valve is working properly.
So - why isn't the boiler firing? Anyone got any ideas?
The only thing I can think of now is the PCB - but that seems to be a bit of a last resort, and an expensive one at that.
The boiler is just over 2 years old, just out of warranty.
