I went to do the washing up and turned the hot tap on and heard a loud ban from the boiler! I turned the tap off straight away but the boiler kept on making the banging noises so I turned it off at the mains. Waited 5 mins and turned it back on, turned the tap on and it starts banging again and carries on banging after the tap is turned off.
When I forced the heating on the pump sounded like it was starting normally then there was a pause and a few clicks (usual sort of relays clicking) then it starts banging again but after several loud bangs the red LED with a symbol of a flame with a line through it lights up like it has overheated.
I did have a look and there are several threads about banging pipes and a few about banging boilers but most of these sounded like more ongoing issues where this has come on suddenly and stops the system dead!
It appears that the pump is running fine but what should I check next?
I don't know if it's significant but 2 weeks or so ago I had to pump up the pressure vessel as the pressure was going too high. It seemed fine after I got the bike pump on it and there didn't seem to water in the air side of the vessel and it has been fine since then till tonight!
Thanks in advance for your help!
