Hi Guys/Gals
The boiler is approx 4 to 5 years old
Bit of a strange one for you heating works fine, hot water however works fine too but as soon as you mix the hot water with the cold water the boiler turns off but then as soon as you turn the cold water off the boiler fires up for hot water..
So basically hot water on its own is fine but if you find it hot and want to mix it with cold it turns the boiler off, its the same problem at the bath tap, sink,basin and shower mixer never had this problem before always worked fine.
Any help appreciated guys
