I have a Baxi Maxflow Combi WM giving some problems.
With it set to CH & DHW and the temperature settings set vertical and the DHW in need of warming, when first switched on at the mains, everything works normally; the HW light lights, then the flame light lights and I can hear the woof of the burner as the gas ignites.
However, after about a minute the burner goes out, as does the flame light and then either:
1) doesn't relight
2) the flame light flashes with about a 1 sec interval
Switching off, leaving for some minutes then switching on again is the only way I have found of getting the burner to go again, but only the once.
Also, when set to DHW only, the hot water light doesn't always light.
The boiler is about 4 years old and this problem has appeared intermittently for about a year.
Any thoughts?
Thanks,
Mike
1) doesn't relight
Any thoughts?
Thanks,
Mike
