Help please
My Baxi Solo 2 50 PF is not starting when I switch on the CH controller. The pilot light is off and isn't firing up when you select CH or HW to be on, on the controller.
The pump and fan are not running either. I've noticed charring on the underside of the PCB - the fuse on the PCB had also blown. I've since replaced the fuse but it still doesn't work
Could the PCB be knackered? What voltage should be present on the PCB terminals? When I select CH on the controller should I have 240v on the Live, SW Live and Pump Live?
Thanks in advance
Thanks in advance
