- Joined
- 29 Aug 2010
- Messages
- 22
- Reaction score
- 0
- Country
I am begining to suspect the pcb may have gone to silicon heaven.
before I order one I need to check all components connected to it to make sure one of them isn't dragging it down.
Valve coils - Both have some reading, not short or open so I'm hoping they're ok.
Thermostat and over heat sensors seem to be giving expected readings.
Fan - I have directly connected a supply to it and it spins ok.
I've tested the potentiometer that sets the heat and turns it all on, that's definately fine.
That leaves one thing, the pressure switch. How can I test that? Can you simply suck on the tube whilst metering the connections to see it switch ? Does it swicth at low enough pressures?
Why does it have two pipes?
I have just found something else. The water pump is not being switched off at all whilst the supply is on the boiler even though heat is not being called for. I read somewhere (I've read that many manuals and forums now I can't remember what came from where
) that the pump does run on for a while (8-10 minutes) after the heat is switched off but I've left it for an hour now and its still powered up.
