i have a baxi boiler it has 2 dials on it 1 for the pre heat for the hot water the other for the rads where should i have the dial for the rads i have a room stat
Usually it is set according to the weather, near maximum or maximum in very cold weather, basically just enough to get your house to the temp set on the thermostat.
