Following on from a question that I've asked in the Building section of the forum...
I'm planning to break up and remove a concrete path outside my kitchen. As part of the job I'll be replacing an old yard gully which is cracked, and joining the new gully to the existing drainage before resurfacing with flagstones and bricks.
What type of bedding material should the pipework and gully be set in before backfilling? I think I read somewhere that the gully should sit on concrete so that it doesn't sink, but I'm unsure as to how the pipework itself should be set, if I end up breaking a significant part of the clayware. Hopefully I can save as much of the original pipe as possible.
Is it possible to cut a clayware pipe with an angle grinder, or does it need to be done with a pipe cutter?
