We have a Beko DFN16210W dishwasher which has started to leave all items in the top rack dirty. Upon closer inspection I have found this to be due to the top arm not rotating. I have taken it off and cleaned it thoroughly, and water freely comes out of the holes but it just does not spin. The bottom arm spins fine and items in the lower basket are all cleaned OK.
From researching this problem it suggests there is a blockage somewhere or the water pressure is not sufficient to spin the arm.
One thing I read on another thread was talk about where the top arm pushes onto the inlet pipe at the back of the dishwasher and the seal may be damaged. Now, I found on the base of the dishwasher a round black soft seal type thing, which seems to fit exactly the size of the inlet pipe. But does it sound like this has come off somewhere and could be causing the issue? I can't fathom out where it should go nor how to attach it, I can't just push it into the pipe hole surely.
Any advice gratefully received. Thanks.
