Beko SG582 Gas cooker
4 Nov 2011
London
The door wont close I suspect the part on the door where the metal clicks into is faulty. Anyone know if you can get that part indvidually or is it a new door?
Hi the SG582 has a pull down door and the hinge has a small metal piece which flips up to lock the hinge into position so that the door can be removed check that this hasnt "flipped up" on one side (compare with the other side) if its ok then it may be the hinge which can be purchased seperate. All parts can be purchased seperately and quite cheaply too. If any weight has been placed on the door at anytime or if the door has been allowed to drop down on its own when opened then the hinge supports (where the hinge enters the cabinet) may be damaged.
