Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
RTN is generally tamper return. TRG is trigger the former is a continuation of the negative feed through the bell tamper back to the control panel. The latter is usually a switched negative fed from the control panel which activates the bell. More info is required for a definitive answer e.g make and model of bell and control panel
