can someone confirm to me if the electrodes are not sparking on the burner this indicates that the control box is not working? would appreciate a response. cheers
No you can't just blame the control box. that controls the input side of the transformer only. The transformer might be the problem or leads etc.
When I had a similar problem. I tested mine using a different power source without the control box and it still didn't work.
When I got new transformer I bench tested it with electrodes to prove it was OK before fitting to boiler with control box..
In fact I also tested motor/pump and the pump solinoid without the control box and ran boiler for ten minutes to make sure everything worked ok before I wired in the control box. (Mind you mine is not a bentone)
checked electrodes for cracks they were good, also checked leads they were fine. I even double checked the position of the electrodes in relation to the nozzle and guess what eh ok.
A failed photocell may also cause this condition, but if it is a Satronic control box, then it might well be BOTH the control box and the ignition unit, as a control box fault can wreck the ignition unit.
