Hi - I'm trying to seal my garage door to stop the cold getting in (the room above the garage gets very cod in the winter).
Below is a picture (it's sideways) which shows about a 20mm gap between the garage door frame and the door itself. I'm trying to think of the best material to use to stick/nail to the inside of the door frame to minimise the draught.
It seems that you can't buy the self-adhesive type normally found in DIY shops for 20mm gaps.
The best thing I can think of is to cut and use some foam pipe lagging, but before I go ahead, I wanted to see if anyone has any better ideas?
Many thanks.
Many thanks.
