hi guys been a while so ill give you problems first, neighbours boiler drains down and knocks on ignition ive found that a rad valve is leaking somewhat, drain valve unaccessable.
having used the canned stuff to freeze pipes and found the ice brick unplugs to easy which will be the best way to stay dry.
next part is for query/ diagnoses
the boiler is ideal condensing boiler fitted with a external gauge for pressure, the neighbour has noticed that when he tops the boiler up daily to 2 bar the pressure indicated rises during ch use only to just below 3 bar, i know ive not yet come across pressure related problems advise welcome on this.
im kinda thinking pressure could = leaks if some sort of blockage existing in existing pipe work????
