Sorry for the essay...
Came to turn the tap on a couple of weeks back and no hot water. Went to the boiler, it was locked out. Pressed the little red button and the boiler fired up ok only to lock out 5 or so seconds later. It keeps doing this, 5 seconds and it locks. It also keeps the ignitor going right up until it cuts out. The boiler will not stay on. Seems to me like the flame isn't being detected.
I changed the detection electrode and aligned it exactly as the old one and as per manual. No joy. I have a corgi friend who got hold of an ignition sequence board for me and told me it was easy to fit. The fault is still there. I am an electronics engineer and I have gone over the old board. No fault that I could see, maybe a leaky diode, but the new board would have cured the fault if that was the case. Checked connections, looked for dry joints, none.
The pump is working fine, the fan and air pressure switch are working ok (boiler firing up). Turn on the hot water the boiler fires up and the pipe just manges to get warm before the boiler shuts off. CH does the same, pipe gets warm and then shut off.
I'm stumped and my corgi mate is sunning himself in Florida for three weeks and I need this fixed. If I need to pay an engineer then so be it, but I was hoping you guys might have some ideas as to where the fault might be. Any help would be appreciated.
