dhw working fine but when switched to heating gives low flame then cuts out ,this continues heaters heat up to low temp ,any ideas ,will faulty pump cause this?
Yes but so will a blocked diverter valve or other blockage in your heating circuit, theres sometimes a filter on the return pipe.
Check that the pump is spinning and that its on its highest setting if applicable, also that the valves to the flow and return underneath are fully open
