Hi All,
I have a problem with my Biasi M90E 24S boiler, which is about 9 years old.
When I switch the heating on it normally works for about an hour, then the hot water and the radiators will go cold, although the boiler still sounds like it is working.
I have to switch the heating off for about 10-15 minutes and then turn it back on again, where the same thing happens.
However over the past few months it has become more unpredictable, from turning it on and it will work all day long (heating and hot water), to only lasting for about 20 minutes. This morning the hot water took over an hour to get hot again.
As you can imagine this is quite annoying.
I did get a plumber out to have a look at it and they said it was a faulty sensor (not sure which one) and they replaced it, however this made no real difference.
I called them out again and they said that another sensor needed replacing and gave some other unhelpful advice.
I would be grateful if anyone could give me some thougths on why this is happening and what can be done to fix it.
My wife is saying we need a new boiler, but I am hoping that this problem is something easy to fix and I don't need to get a new one.
Stuart
Stuart
