Biasi M90F 24 won't ignite
17 Aug 2012
Hi, I wonder if anyone can help.
Out of the blue my Biasi M90F 24 boiler failed to light when a hot tap was turned on. I checked the panel and found the lock out light was on so reset and tried again, the fan ran and there was the usual clicks and noises until the lock out light came on again. I checked the fill pressure was ok (1 bar) and the gas was on then after about half an hour of messing about turning the heating / hot water on and off and resetting the lock out it eventually lit. It was ok for a couple of days then did it again and after some time doing the same as before finally I got it to fire up again. last night again it did the same thing but I could not get it to light this time. Could anyone give me some pointers on what might be the problem might be?
many thanks!
It sounds to be a gas/combustion related problem which we dont advise on in the public forum.
The obvious advice is to get a gas registered engineer.
Tony
