BIASI PRISMA ON THE BLINK
7 Nov 2005
Hi Guys Ps help i'm in big trouble :cry:
I have a 5yr old Biasi Prisma and the hot water will only work when it is fired up in the Cntrl Htng mode! It was only recently fixed after it kept locking out (crap on the fanfins) I know your going to say 'get a worcester' but at present i am a bit strapped for cash and need to fix this temporally! Is it a Diy job or do i need a engineer? :?: Thank you!
Its a perfectly good boiler if it has been professionally installed. They have a bad name because they are quite cheap to buy and tend to be used by cowboy installers who want to do a cheap job and dont treat the water.
Your problem is caused by a failure of the hydraulic unit in the diverter valve. Its a somewhat fiddly job but some DIYers have managed to do it themselves.
Tony Glazier
Is it expensive to fix or buy? Cheers
Edit: Cant seem to find what you said in the biasi repair/spares brochure,is it on the water or gas side? :D
Would it look like a 5"high round black plastic thing with a brass bottom looks simular to an old car perol pump!
