Hi guys,
Got a situation with hot from a combi and tank fed cold so the customer wants the tank bypassed and cold hooked up to the mains. I come across this more often than I'd hope, but this case is a little unusual.
Firstly, massive asbestos tank, so no cutting that up (or even moving it into the corner of the loft as it's so heavy).
Secondly, the confusing bit - the supply to the ball valve is 3/4 inch copper, fair enough, and the old cold feed for the hot (capped 6 inches from the tank) is also 3/4 copper. However, cold supply from the tank to the bathroom and separate toilet is black plastic. Looks like about 28mm (or 1 inch probably) and there's also a couple of tees off this in 3/4 black plastic pipe. The pipe feels like MDPE (except it's black).
So, does anyone know what I'm dealing with here? Is it old school imperial MDPE that's been used to supply a bathroom for some reason? and is this commonplace anywhere? Only place I've come across anything that looks like this stuff before was on an old stable yard... And are fittings readily available for this stuff?
Any advice gratefully received....
Cheers
Cheers
