Bleeding radiators, air releasing but not water???
21 Jun 2006
Plymouth
Hi, I've had air in some of my radiators (well most!) so I've been bleeding the air our of them but on a couple of radiators (upstairs) I've had lots of air coming out but then the air stops hissing and I don't get any water squirting out that you normally would do. Also the heater is heating up better but the top of the radiator remains cold?
Any advise would be welcome!
If it is a conventional open vent system check your small header tank in the loft is full of water. If it is you will have a blockage in the cold feed from the header tank where it t's into the rest of the pipework.
If its a combi or system boiler you need to repressurise your system with water before continuing to bleed rads.
Have you turned the system off while you are doing this and where are these two radiators?
Stan
Both radiators are upstairs (bathroom and a bedroom). I've tried bleeding with boiler off and then again when on! I know I shouldn't have when on! The boiler pressure is sometimes struggling with low pressure, so perhaps it's this!
