I've recently moved into a fairly new house. The problem is with two upstairs radiators, the bottom half is hot, top half is cold. I tried bleeding them but only a small amount of air came out of one and none at all out of the other. The pressure gauge on the boiler doesn't move off 0 bar, yet the HW system is absolutely fine and all other rads are fine too. Is this a fault with the gauge, or should I try to repressurise the system?
There is a flexible silver hose in the airing cupboard, from reading through this forum do I just need to open up the valve on that until the gauge moves to just under 1.0 bar and rebleed? Or could there be another problem I should investigate first?
Thanks in advance!
Matt
Thanks in advance!
Matt
