How do I repressurise my combi boiler?
26 Sep 2003
Have moved into a new property and the boiler has stopped working (Ariston Eurocombi SX20). Pressure gauge reads 0 bar, so system obviously needs repressurising. But I can't work out how to do this. There is not, e.g., a filling loop with a valve beneath the boiler, like I've seen in the past. Where else might this be located? Could it have been removed, and if so how would I refit it? Any suggestions gratefully received!
Robert
Hi Robert'
As you know water has to be transferred from the cold water mains into the boiler to pressurise it.
You need to find a valve on the cold water mains which has a screw thread to match the thread on the loop.
Also you need to find another similar screw thread connected to a spring operated valve so once you have reached the desired pressure it will hold it.
The loop itself is just a plastic pipe covered in braid with a hand operated connector either end, which is normally removed to prevent unwanted tampering.
I can't see any other way so I would think the valve must be there somewhere. Perhaps you need to remove the boiler cover, I wouldn't think a permanent loop had been fitted.
Isuppose you could contact the boiler manufacturer for advice
:rolleyes: :rolleyes: :rolleyes:
