Hi everyone in my front garden and drive the previous owner planted 3 huge conifers right next to the block paving and has came up in a few places , I recently cut the conifers down and I am currently digging out, I had to remove a bit of the drive and put back best I could using sharp sand and knocking down with hammer and bit of wood will sweep in killin dried paving sand when done but the edges and all sinking into the grassed section of garden , should I dig out conifers then fill holes then worry about the edge by digging a hole along behind the edging and removing the edging and laying some hand mixed 3:1 ratio cement under the edging stone and a little behind it?
Do I need anything under cement or just straight onto the soil and how deep ?
I relise edging is normally done first but just hasnt worked out that way as needed to lift up, also the speed is loose going into house should I knock away old cement underneath and lay new cement under the 1 brick that is loose and do I need cement om sides of the larger stone to get into house ?
What cement do I need just lafarge bag from b and q do the job
Sorry if been asked a hundered times before but ahy help is greatly appreciated
dean[/img]
dean[/img]
