- Joined
- 11 Sep 2007
- Messages
- 769
- Reaction score
- 31
- Country
Hi Guys,
House with indirect cylinder etc on the ground floor, radiators on ground floor getting hot, as does the water in the cylinder, the upstairs radiators are the problem, with none of them getting warm, tried to bleed radiators but nothing happened. turned valves of to one radiator, removed valve from radiator and nothing came out of the radiator, so empty, opened the valve to check and suprise suprise, no water. So no radiators in the upstairs are getting water.
Checked F&E, this has plenty of water, would I be right in thinking that the cold feed from the F&E is blocked somewhere?
The route of the cold feed is as follows, out of the F&E and across the loft for about 4 meters, elbow down then a straight drop to ground floor where it connects to the bottom connection of the coil, on this pipe run just above the cylinder is a gate valve which I have checked and is open, there is for some reason an isolation valve on the pipe as it leaves the F&E, again this is open.
Do you think I have a blockage in one of the elbows? Whats the best way of tackling this one?
I was thinking switch of boiler, close gatevalve and isolation valve stopping water leaving the F&E, cut out the elbow in the loft and see it that is blocked the work my way down the pipe run and try to track it.
Sorry for the long post but wanted to give as much info as possible.
Look forward to your thoughts on this.
Cheers
Cheers
